DIY Guides for the BMW E70
BMW E70 Center Speaker Wires
https://drive.google.com/file/d/1BZkfzG ... sp=sharing
E70 Center Console Trim Removal & Installation
https://www.youtube.com/watch?v=QaOdIUn8hzE
https://www.youtube.com/watch?v=0KnO2Qv_dWk&t=13s
https://www.youtube.com/watch?v=O74Bb0xhbgY
BMW X5 E70 - How To Remove the dash center panel
https://www.youtube.com/watch?v=re4xwxHrEfI
Removing the display screen and central locking BMW X5 E70
https://www.youtube.com/watch?v=FyYL7cE1C9Y
BMW X5 E70 Dash components removal + CCC DVD Replacment How to DIY: BMTroubleU
https://www.youtube.com/watch?v=Mp3uIM77Fiw
How to Remove CCC / Navigation / Radio from BMW X5 2009 for Repair.
https://www.youtube.com/watch?v=AJ5Y37jn3dQ
AVIN USA 10.25" Android E70 CCC
https://www.youtube.com/watch?v=ixpC5T5Xe2Y
BMW EVO User Manual
https://drive.google.com/file/d/0B5csZB ... sp=sharing
Step 1: READ ALL OF THE QUICK START GUIDE!
Almost all settings including those for the iDrive control can be found in the factory settings menu.
Please take some time to carefully go through the Quick Start Guide. It will have a lot of solutions to help you get set up.
Quick Start Guide For BMW EVO.pdf
No sound?
You must connect the 3.5mm audio cable from the "AUX-OUT" on the MAIN harness to the AUX input under your armrest. (Do NOT make the mistake of plugging this 3.5mm cable into the MIC-IN)
Check the IDRIVE AUX volume is set to MAX.
Step 2: DO NOT FORGET TO PLUG THE GREEN FIBER OPTIC CABLE BACK INTO THE FACTORY RADIO.
Step 3: If your CCC IDRIVE control is not working you have to change the IDRIVE setting here.
Step 4: Set the clock setting to "ORIGINAL TIME". Doing this will save the TIME setting when you restart your car.
Step 5. Make sure you have the CAR TYPE setting correct for your BMW model. THIS IS VERY IMPORTANT! The correct setting for your model is on white label that your monitor came in.
DO NOT CLICK "Update Config". That is not how you change the CAR TYPE setting.
Follow these step:
Click on the option that matches your car model. A popup will appear then click the CHECK mark to save the settings.
Reboot your unit for the settings to take effect.
MirrorLink Android Phones Connection Guide -
www.avinusa.com
AVIN_BMW_F30_10.25_Android_Monitor_Upgrade_DIY_Install_Guide_-_BMWF30A-1025
Troubleshooting Tip:
Symptoms: prolonged BMW screen at startup, then "NO SIGNAL" when switching to "original car," no audio, iDrive controller only partially worked in the AVIN menus, and green SOS light in headliner occasionally blinked.
Try rebooting the iDrive system
Push both eject buttons (DVD and CD) and the volume knob (a.k.a the mute button) at the same time. Wait about 30 seconds for the factory system to complete its reboot.
http://www.bimmerfest.com/forums/showth ... p?t=254420
