Accessoires M Performance pour X2, X3, X4
BMW propose depuis cette semaine quelques accessoires pour les nouveau X2, X3 et X4
Grille de radiateur, volant, jantes, éclairage M Performance, coque de rétroviseur, marquage adhésif, il y en a pour tous les gouts et de quoi personnaliser votre X sans tomber dans le tuning.
Refined looks based on details inspired by motor racing.
M Performance lettering is one particularly effective way of creating a visual highlight. Designed to ensure an ideal match with the model in question, the side lettering in Frozen Black underscores the sporty character of the vehicle, in particular emphasising the dynamic proportions of the body. In addition to the side lettering, the appearance of the BMW X3 and BMW X4 can be further refined with the front lettering in high-gloss black – matching the other front attachment parts for these two models, which also feature a high-gloss finish. M Performance front radiator grilles in high-gloss black are available for the BMW X2. These have the same geometry as the standard grilles but are much more visually striking, thereby underscoring the vehicle's sporty flair and dynamic performance.
The M Performance exterior mirror caps in carbon fibre are another eye-catcher available for all three series. They are crafted elaborately by hand from carbon fibre reinforced plastic (CFRP). With several coating layers and finished with a high-gloss polish, the carbon fibre caps have a depth effect which gives them a compelling appearance.
Sporty, elegant refinement on the inside.
The interior of the BMW X2, BMW X3 and BMW X4 can also be enhanced for additional sporty flair by means of select details, while at the same time increasing feel-good comfort on board. The M Performance floor mats are a potential contributing factor here. They are made of velour velvet with a leather-look surround and contrasting decorative seams. Their soft material makes them especially gentle on shoe heels. The front mats for driver and passenger bear the M Performance branding.
The M Performance steering wheel ensures the driver of a BMW X2, BMW X3 or BMW X4 retains a perfect grip on everything. It has distinct, specially lined grip areas which are covered with Alcantara. This microfibre fabric similar to suede is exceptionally pleasant to the touch in all temperatures and provides an optimum hold. The upper and lower part of the steering wheel are also covered in high-quality leather, as is the accompanying steering wheel trim panel. A red motorsports marking in the 12 o'clock position emphasises the car's dynamic qualities, as does the silver-grey, hand-sewn cross-stitch seam. Steering wheel trim panels are also optionally available for the BMW X3 and BMW X4 in carbon fibre/leather, with central clasp in either open-pore or high-gloss carbon fibre.
Shift paddles at the steering wheel enable the driver to change gear without taking their hands off the steering wheel, thereby facilitating vehicle control even when driving in dynamic style. For the BMW X3 and BMW X4 with this feature on board, the shift paddles are available in high-gloss carbon fibre. They are covered in an extremely fine carbon mesh, enhanced with a PUR finish and a high-gloss polish, and also feature plus and minus symbols in anodised red.
Extensive range of attractive summer complete wheel sets.
Much of a vehicle's design is perceptibly dominated by its wheel/tyre combination. This is why adaptations in this area have traditionally been among the most popular customisation measures in the automotive sector. This also accounts for the wide range available as part of the BMW M Performance Parts program. The 20-inch summer complete wheel set Styling 717 M is available for the BMW X2, for example. The matt black finish of this light alloy wheel, weight-optimised by means of flowforming technology (rolled rim well) adds a particularly striking touch of sporty flair. The 19-inch M Performance light alloy wheel Double Spoke 698 M in Orbit Grey is available as a summer complete wheel set for the BMW X3 and BMW X4. The exclusive finish and visible wheel bolts are key contributing factors to an impressive appearance here. The 21-inch forged wheel Y Spoke 701 M Bicolor is currently the largest wheel in the program of Original BMW Accessories for the BMW X3 and BMW X4. It also has a rolled rim well, and it weighs some two kilograms less than a similarly designed cast wheel in the same format: this is because of the special manufacturing process used. The Bicolor look with black as the background colour and the burnished finish on the visible side make for a very eye-catching impression, especially due to the high-quality clear finish.
Light installations for a highly effective appearance.
One discreet customisation option that also adds a definite touch of exclusivity at the same time are the BMW LED door projectors. They replace the standard entry light and project a graphic onto the ground when the door is opened. The selection of motifs include the BMW M logo as well as various motifs from an M Performance slide set.
Re: Accessoires M Performance pour X2, X3, X4
génial , les naseaux noir mat comme sur mon X6 F16...je les fais monter dès réception de mon X3 ... :Top: :cheers:
Lanthanides
Voiture : X3 G01 M40i
Message par Lanthanides »
Le volant ! :shock:
Je vais demander au vendeur UK si possible de le prendre à la place du volant sport d'origine !
Sympa aussi les 21 pouces, je sens que je vais avoir du mal à résister à rester en 20 pouces...
stph57
Voiture : Bmw X3 G01 30d MSport
Message par stph57 »
Auriez vous par hasard un lien vers le site?
Dernière modification par Thomas le 04 mars 2018, 18:03, modifié 1 fois.
Raison : Suppression de la citation
Vers quel site ?
stph57
Pour les accessoires M Performance qui sont cités dans votre article
AMHA il faut s'adresser à ton CC BMW...
Pièces en vente ... chez BMW, ou chez notre partenaire.
j'ai appele le CC BMW ce matin, les pièces M performances X3 G01 ne sont pas encore référencées. :roll:
on est trop rapide sur le forum.....
Anagenisi
Voiture : BMW_X5_M50D
Message par Anagenisi »
vous pensez que le volant est compatible pour un X5 F15 également?... je le trouve sympa ;-)
Merci,
Ne regrettons rien...
Bobbylechat
Voiture : X3 30d G01 m sport phytonic 721
Message par Bobbylechat »
Comme quoi les goûts et les couleurs...
Perso je trouve ces accessoires moyens, rien de transcendant
tomducat
Voiture : BMW X4 20D xline ba
Message par tomducat »
Idem assez déçu , les jantes ne sont pas terribles .
Seul le volant est sympa avec ces touches d'alcantara.
Les naseaux black et les coques de rétro en carbone c'est du déjà vu .
Les naseaux c'est déjà vu mais indispensables sur toute la gamme quand on ne veut pas de chromes, ce qui est mon cas :D
a
ayo
Voiture : BMW M140i xdrive
Message par ayo »
Personnelement je ne suis pas un grand fan des jantes proposées, tout le reste me plait même si je trouve que le volant aurait pu être totalement rond au milieu et pas une forme que je ne serais qualifier mais qui ne me plait que moyennenement. Sinon le carbon, etc c'est juste magnifique!
Bourne
Voiture : C 450 AMG SPORT
Message par Bourne »
Les volants en cuir / alcantara sont magnifiques, mais attention à l'usure;
J'en ai un sur ma voiture (volant d'origine AMG) et les parties de grip sont en alcantara et s'usent rapidement.
L'usure dont je parle n'implique pas que la zone en question se déchire ou se fissure mais on voit rapidement les traces car ça se rape et change de couleur.
Ce n'est que mon avis. :roll:
tomducat
Faut se laver les mains avant de monter dans la voiture :lol:
je trouve très sympa les jantes anthracites, malheureusement en 19' :lol:
perso, pas fan de l'aspect de l'Alcantara, surtout sur des sièges. l'aspect n'est jamais net...
Stark31
Voiture : BMW X3 G01 30D M
Message par Stark31 »
Toujours rien en CC, l'accessoiriste n'était meme pas au courant...
bg34
Voiture : BMW Série 1 F20 2016, BMW X3 G01 xLine 20d 2018
Message par bg34 »
Bonsoir à tous, toujours rien concernant la disponibilité en concession des accessoires m performance pour nos G01 ??? :bounce: :(
J’ai passé commande d’une jolie calandre noire et silence radio complet de mon concessionnaire :scratch: Avez vous du nouveau ? Merci par avance.
bg34
Message par bg34 »
