Les 2 Menus cachés de l'iDrive2
Publié : 09 nov. 2012, 22:34
Je crois que j'avais déjà lancé un post à ce sujet, mais comme je ne le retrouve pas, le voici à nouveau :
Voici la façon d'accéder aux 2 menus cachés de l'iDrive 2 :
[video][/video]
Voir la vidéo ici : http://www.bmw-sg.com/forums/bmw-5-seri ... menus.htmlExtracted from Bimmerpost:
Speedometer LCD,
1. Hold down the odometer reset button and turn the ignition on by pushing start/stop button.
2. Release the odometer reset button, and you should see a menu of 4 items on the dashboard. From here on, use the odo-reset button to advance to the next entry through a short press, and to select through a long press.
3. Choose the one that says Unlock through the above, which will take you to a passkey screen. Your passkey is the sum of the last 5 digits of your VIN. Increment the two-digit number until you get to it, and with the long press of the odo button, select it.
4. Then you will see a list of the extended menu. Short press to advance to next, Long press to select.
Now for iDrive, there is another set of hidden menu:
• Call up Start menu
• Push controller in up direction for at least 10 s.
• Controller 3 notches to the right
• Controller 3 notches to the left
• Controller 1 notch to the right
• Controller 1 notch to the left
• Press controller once.
• The Service menu is now added as the last submenu to "Settings".
Four selection menus are available in the Service menu of the CIC:
• Navigation
• Telephone and BMW Service
• TV (Not for US)
• Gracenote
[video][/video]
