bon j'ai réussi a extraire un report error memory
la liste est longue
C'est grave?
J'ai roulé encore ce matin est rien ... aucune alarmes
en tous cas c'est cool de m'aider a comprendre cette BM
Error Memory
Junction Box Electronics
2 errors
8020E8: Terminal 30F reset / shutdown
802102: Undervoltage detected
Crash Safety Module
2 errors
930AA1: Supply voltage: undervoltage
930AA3: Supply voltage: Undervoltage detected in self-test (PDC)
Switch center, steering column
2 errors
803428: Undervoltage LIN
803434: Undervoltage SZL
allround-view camera
1 error
800B9F: Undervoltage detected
Digital Motor Electronics
8 errors
210901: Generator, communication: no communication
174308: Secondary air valve 2: stuck closed
213901: Consumer reduction: active
2
20A202: Coolant pump for charge air cooler, power-reduced operation: undervoltage
CDB404: FA-CAN, message (vehicle status, 0x3A0): missing
213401: Power management, undervoltage: undervoltage detected
1D3B01: EGS, signal monitoring (gait information): invalid signal content
213501: Power management, battery monitoring: deep discharge
Digital Engine Electronics 2
2 errors
CDF404: FA-CAN, message (vehicle status, 0x3A0): missing
200500: DME, internal error, monitoring of external torque demand: transmission signals
implausible
Active steering
2 errors
480214: Undervoltage at terminal 15n (<9 V)
480215: Undervoltage at terminal 30 (<9 V)
Electronic transmission control
3 errors
420511: EGS power supply: voltage too low (7 to 9V)
4209A4: Temperature sensors: Hotmode 3 - excess temperature detected with possible
damage to the transmission oil cooler lines
420571: EGS power supply: Outside the specified range (<6.5V)
Integrated Chassis Management
2 errors
480006: KL30 undervoltage
48003B: SG error LRR / FRR status
Parking brake
3
2 errors
480515: Power supply - control unit - undervoltage
480517: Power supply - cable puller - undervoltage
Rear-axle slip-angle control
2 errors
480395: Undervoltage at terminal 15n (<9 V)
480396: Undervoltage at terminal 30 (<9 V)
Top HiFi amplifier
2 errors
B7F4E0: Logic part: Undervoltage detected
B7F4E1: Load part: undervoltage detected
Electronic Ride-Height Control
2 errors
480DC6: Ub undervoltage
480DC8: Ub operating voltage below the permissible range
Vertical Dynamics Management
3 errors
480B81: KL30 undervoltage
480B83: KL15N undervoltage
D76D61: Signal (1.0.1, Funktion_Radknoten_HL): Qualifier incorrect
Head-Up Display
1 error
800182: Undervoltage detected
4
Car Access System
3 errors
930700: Undervoltage KL30L / KL30E
93076A: Deactivation of terminal 15: OSFG reached, but switch-off preventer active
93076B: Deactivation of terminal 30B: OSFG reached
Roof function center
2 errors
801A38: undervoltage
801A3A: DWA alarm, details in alarm memory
Gear selector switch
1 error
802696: undervoltage
Instrument panel
4 errors
E12C01: Tank level sensor left: short circuit to supply voltage or to ground
E12C03: Tank level sensor right: short circuit to supply voltage or to ground
E11480: Message (Alive counter security, 0x0D7) missing, receiver KOMBI, sender ACSM
B7F685: COMBI: Undervoltage detected
Car Information Computer
1 error
B7F86B: External undervoltage
Controller (iDrive)
1 error
801405: Undervoltage detected
5
Seat module, driver
3 errors
8029D4: Undervoltage detected
E4440B: CAN bus Physical bus error
802A08: PIA: Porting restricted due to missing calibration
Front passenger seat module
2 errors
802BD4: Undervoltage detected
E4840B: CAN bus Physical bus error
Footwell module
5 errors
800ED7: Door contact BFT_H Line break or short circuit to Ub
800F92: Welcome Light repeat lock active
800FA8: ELSV undervoltage
E58C3E: K_LIN_1 Bus Error outside mirror left
E58C3F: K_LIN_1 Bus Error outside mirror right
Central Information Display
2 errors
800352: Video connection: LVDS-Lock is missing
800370: Undervoltage detected
Integrated automatic heating / air conditioning system
2 errors
801253: eKMV: Power reduction in cooling or heating operation through power management
80120D: Undervoltage detected
6
Rear-cabin automatic A/C
2 errors
801022: Undervoltage detected
80102A: Heating / air conditioning system: output reduced due to reduced consumption
Damper satellite, front left
1 error
480F20: SG internal: undervoltage detected
Damper satellite, front right
1 error
481120: SG internal: undervoltage detected
Damper satellite, rear left
1 error
481320: SG internal: undervoltage detected
Damper satellite, rear right
1 error
481520: SG internal: undervoltage detected
